O
Octopus
All,
I'm after a sanity check on an customer job I'm looking at. The basic problem is that to get power from the ring, the the required point is near on impossible inside teh house but realitively easy if part of the run is outside, about 6 foot above the ground.
So the question is: can I use SWA cable purely for the mechanical protection and not have to connect the swa to the earth at each end?
Your thoughts please and thanks!
