View the thread, titled "Would this need Part P?" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
P
PVKitsDirect
A system to control an immersion heater from excess generated PV power.
The control unit uses a clamp round the mains at the meter and wirelessly turns on the immersion element. The existing immersion isolator is replaced with a new fascia with the wireless gubbins inside.
So, no new wiring is required.
Would it need Part P?
Thanks - the only thing it might need is a 13A supply near the meter to power the controller.
That obviously would require Part P - correct?
not just part P you could use a fully qualified electrician (part P is one route to work on a domestic property)
If you are just adding a socket or an FCU to an existing circuit (not in a kitchen/bathroom/outside etc) then you would not need to notify the change under part P, it would just need the usual electrical installation inspection testing and certification.
Reply to the thread, titled "Would this need Part P?" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
