would you put a modern cooker on with the kitchen ring? | on ElectriciansForums
Discuss would you put a modern cooker on with the kitchen ring? in the Australia area at ElectriciansForums.net
J
James sparks
Hi all,
Just wanted to get some other opinions of wether you would put a new double oven on with the kitchen ring? The oven's highest consumption setting is the grille, which it has two of at 2000W each. This comes out at about 16-17A.
Other appliances on the kitchen ring will be:
fridge freezer
washing machine
dishwasher
microwave
kettle
toaster
Just wanted some opinions on what you lot would do and the liklihood of too many appliances being on at once (ie christmas when everything will be on)
The hob will be on a 6mm radial as it's about 6kW. So i'm thinking of putting a 4mm/2.5mm radial in for the oven but need to keep the cost down for the lady.
Reply to would you put a modern cooker on with the kitchen ring? in the Australia area at ElectriciansForums.net
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
