Wylex 100a DP Isolator (meter/CU) | on ElectriciansForums
Discuss Wylex 100a DP Isolator (meter/CU) in the Australia area at ElectriciansForums.net
Need to fit an isolator as above. Now not much room in meter cupboard (old radio teleswitch) to mount the isolator vertically. would there be a problem if i mounted the isolator horizontally? making sure the load and supply were correctly fed?
Would a KMF type switchfuse be any better for you, or is it SWA you're terminating???
no not swa just meter tails. exisiting tails do not need replacing but theres not enough slack to accomodate fitting the isolator vertically and the teleswitch makes it very tight. fitted horizontally there is enough slack in the tails and teleswitch will not impede.
Reply to Wylex 100a DP Isolator (meter/CU) in the Australia area at ElectriciansForums.net
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
