Wylex bs5419 60 amp switch fuse
K
KEVINDOE
Hi guys,
Need to upgrade a 60amp wylex bs5419 to 80amp, will the 80 fit the carrier ? not got one on board to try , or does it need to be a new unit ??
Thanks Jem :confused:
Hi Nick,
No its the push in carrier, Its protecting tails that exeed 3 meters , hot tub and other stuf installed so prob need to upgrade ? max demand now around 92 amps
Hi ////jemm /i totally mis read the post what a numpty , as roger has said they are differant and as you have said max demand now higher i would reccomend you upgrade
