wylex db | on ElectriciansForums
Discuss wylex db in the UK Electrical Forum area at ElectriciansForums.net
I
iamelectric
anyone still fitting wylex consumer units , have they sorted out their problems with the mcbs melting , is it worth still using them?
i always fit the wylex boards and never had any issues. i have also fitted the BG ones the off chance the customer gets the materials. just stay away from the mk ones. pain in the arse to fit.
picked one up earlier , looks ok apart from the internal wiring of the rcds ,oofft needs tidied up its a mess , i usually use proteus , solid links between main switch and rcds , alot neater
Went right off Wylex after the product recall and am still finding boars that are part of the recall (I didn't install them). IMHO the only thing worse than a Proteus board is???
Nah, can't think of anything :)
the MCB problem was sorted 2 years ago. the CUs are OK, but i still prefer BG.
Tel....BG are just a better board....
the enclosure is better...the busbar is meatier....the room in em is better....
- - - Updated - - -
Note the new placing of earth terminal in the 3phase square d boards poor design if you're cables ar top entry witch is about 90% off the time
recently fitted a loadstar.....
no issues there....
Reply to wylex db in the UK Electrical Forum area at ElectriciansForums.net
It's done - I don't know why the RCBO failed but it happens. But can't understand why the live connection is so deep - silly design. But thanks...
