wylex main switch | on ElectriciansForums
Discuss wylex main switch in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
albi
north east england
Hi does any know of a BS number for a wylex main switch on a 3036 DB.
as I have been puting on my certs wylex main switch as I carnt find any ref for them.?????
just found this on another thread, thanks goes to des56 for this.
Hres a couple to start you off
Residual current devices
RCD bs 4293 (old) general purpose
RCD bsen 61008 (new) general purpose
RCD bsen 61008S Time delay S = selective
RCBO bsen 61009 RCD with overcurrent protection
RCD/skt bs 7288 RCD socket outlet
D.P. Main Switches
DP/MS bs 5419 (old) 1977
DP/MS bsen 60947-3 (new)
MCBs and FUses
MCB bs 3871/1 (old)
MCB bs 3871/2 (old)
MCB bs 3871/3 (old0
MCB bsen 60898/B (new)
MCB bsen 60898/c (new)
MCB bsen 60898/d (new)
Fuse bs 1361 Type 1 or11 cartridge fuse
Fuse bs 88 PT/2 or 6 Cartridge fuse
Fuse bs 1362 Domestic 13 amp plug top
Fuse bs 3036 (old) rewireable fuse
Consumer units bs 5486 PT/13
Reply to wylex main switch in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, I hope you are well, a friend has lost power and it's the main switch that has failed I've got a bunch of different brands in the garage...
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
