Soulsurfer
Hi all, does anyone know of any other manufacturers single module RCBO that could slot in and replace a Wylex NSBS 32A type C ?
Screw heads on existing one are smashed to bits & not tightening onto cables enough when checked.
Thanks.
I have Wiha Torque drivers but the install sparks have put in a ring for ground then spurred a 3rd cable off for a socket next to the CU and when doing a test on DB as my parents just moved in to this place. The RCBO Line cables pulled out & head of the screws are chewed up loads so can't tighten right !
Just got hold of every wholesaler here in Jersey on the rock & my mate has 1 left ! B curve too so should be sorted although design of clamp inside that holds cables is V shape rather than squared like Hager so may need to fit that 3rd spurred cable to its own RCBO also. As the Wylex one doesn't seem happy holding on 3 x 2.5's as its been wired!!
Take it as a good thing that theres no Wylex over there! Lol...
Soulsurfer
Channel Islands
Business Name
M.B.S ELECTRICAL
Wylex RCBO SP Replacement.
Soulsurfer,
Brightspark2,
