Xpelair | on ElectriciansForums
Discuss Xpelair in the Australia area at ElectriciansForums.net
T
tonytrying
hi,,
anyone tel me plz wat size cable i wud need to fit Xpelair CXC6 Single speed extracter fan Ref 90850AW,,,will 6m do
thank you :confused:
um, this is a domestic kitchen fan that draws 30W and you want to use 6mm?
Do you really know what you are doing?
6mm will work fine, but it is a tad excessive.
I would suggest that you contact an electrician!
thanks,for reply,,thought i was contacting electricans on here,,the fan is a kitchen as required by building regs 60 liters out put per sec & above, manual states 6m I thought it may av been bit excessive the reason i asked opinion of electricians or wud be electricians on here
regards
Thank you all ,,I can now see why Jason.S is head Moderator,,he can clearly recognoise someone in need, i am asking for advice, thought that was reasonable on this kind of site,,, thank you again Jason and everyone else who replied
xxxxxxxxxx
Thank you for link,,iam a bit thick in the best of times but still cant see wat size cable to use with GXC6 have seen the one other stating can be linked with lighting circuit not sure if it applies to GXC6
thank u :cool:
Reply to Xpelair in the Australia area at ElectriciansForums.net
If you are using Zdb you do not add on Ze as that is already incorporated into Zdb.
Can to OP clarify if this extension is just another room on the side of the building (so multiple cables going through the walls for lights...
