Y Plan Cert | on ElectriciansForums
Discuss Y Plan Cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
dpg2
Alright all had a look at a job today to do a Y plan for a central heating system now im going to spur off from a socet in the bedroom and fit the spur whith a 3a fuse but do I issue a miner works or EIC. All of it will be new clock, stat, cylinder stat, ect, as there was no heating in the house befor just gas heaters.
Meny thanks all
Reply to Y Plan Cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W-plan pump run on Son recently moved into a 20 year old house with what appears to be a W-plan system using, I think a Worcester Bosch Greenstar...
davidwf
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
