J
JAMES_PRIOR
Brand new boiler, pump, room stat, 3 port valve, cyl stat & programmer fitted. Boiler will only fire when cyl stat turned up and then you can control heating from room stat. when cyl stat turned down the boiler will not fire and heating or hot water cannot be controlled. When cyl stat turned down and you call for heat via the room stat the 3 port valve seems to tick as though the 230v feed is being switched on and off. All wiring has been checked 5 times now my head is ready to go bang!
