W
wrinklyazza
At job this morning y plan system but when put on heating and water off the neon on roomstat comes on when calling for heat but when you turn stat down it turns the valve off as normal but the neon on roomstat just goes dimmer and not off. tested at 10 way box and foubnd that there was a feed backfrom the grey off the 3 port valve feeding back down the white off the valve which was the feeding back to the roomstat hence why the neon was dimm on the roonmstat. Anybody got any idea how i can cure this
Only happens when on heating only and hot water off
