V
vintageaxeman
Help required please!
I have a 15yr old house with a Honeywell Y plan.
Recently, in the summer with heating switched off, when the timer calls for hot water, and the wall thermostat downstairs is set very low, the radiators get hot too. It was as though the Honeywell V4073 valve was going to a mid position when only hot water was requested.
I have removed the valve actuator and tried switching h/w and heating on and off separately and together to see what effect this would have on the actuator, and it seemed to turn ok BUT made a horrible ratchetty noise at the end of its travel.
So I have just installed a NEW V4073 3-position actuator, but the problem unfortunately is continuing.
I am now wondering whether I need to drain down the system, and check the valve itself to see if THAT is faulty (ie the rubber ball has come off it's rod or something similar....)
Or could it be the timer has faulty relays?
I don't think it would be the wall thermostat or the cylinder stat, do you?
Has anyone else had this problem or can anyone offer advice please?
Thank you.
Thank you.
