F
feebs73
Help, I have a y plan wiring system I need to change, I have a Drayton wiring system, stat, cylinder stat, wiring loom, time clock, and the plumber has installed a Honeywell valve, is the wiring in the Honeywell valve the same as a Drayton valve i.e. same colors?, regarding the links in the wiring loom do I install all the dotted lines as it says or is a Y plan different.
Many Thanks to anyone who can help
feebs 73
feebs 73
