y plan with wireless stat | on ElectriciansForums
Discuss y plan with wireless stat in the Central Heating Systems area at ElectriciansForums.net
J
jim1976
hi can anyone give me a website or link that has a y plan diagram with wireless stat in honey well and danfoss. every time i wire it up never seems to work quiet right, which is bad as i do it for a living lol. fine with s plan and combi its just the y plan cant work out the wireless connections
i also have problem with pump over run where does that go i cant find a drawing anywhere on any sites
i have all the ones that have wired stat its the wireless ones i need
found one and ive been doing it right but it never seems to work boiler is on permanently for heating and its all new stuff so frustrating. its costing me loads in revisits that i dont get paid for and never sort the problem
honeywell gear?
heating from the clock (4) to A of the receiver then B onto the white of the valve, orange in with boiler switch and water on from cylinder stat.
pump overrrun from boiler (whatever colour you use) onto the pump live, then just neutral and earth
liam b thanks mate ive been putting it in with s/l from boiler but that goes to orange and over run to pump live thats why its not turning of makes sense now. it amazing when you see it how stupidly easy it is lol thanks again
Reply to y plan with wireless stat in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
W-plan pump run on Son recently moved into a 20 year old house with what appears to be a W-plan system using, I think a Worcester Bosch Greenstar...
davidwf
