P
Penance
Been to look at a job today, initially adding 3 dso's to ring final.
Was checking the CU and yes there is no main bond to the incoming water.
The water enters a utility room thru a concrete floor, stop cock and around 2' of copper pipe before changing to plastic pushfit stuff.
The plastic runs for about 10' and reverts to copper.
You know what I'm going to ask!
Does the small length of incoming metal water pipe require bonding back to the MET?
