You call that a bender.... THIS is a bender | on ElectriciansForums
Discuss You call that a bender.... THIS is a bender in the UK Electrical Forum area at ElectriciansForums.net
I think in the USA they have different gauges of conduit, though ones is called EMT (electrical metal tubing) and might be bendable by hand that way.
For anything like that size I would be looking at a hydraulic press style of tool!
No. This is a bender…..
Sorry. Someone had to do it!
[ElectriciansForums.net] You call that a bender.... THIS is a bender
I've only ever used 32mm conduit once on a job I was on about 40 years ago, an older spark who was a year or two from retiring I was working with ended up in hospital with badly bruised ribs from the effort needed bending it in a Hilmor conduit bender.
I think trunking is a better option than using anything over 25mm
Reply to You call that a bender.... THIS is a bender in the UK Electrical Forum area at ElectriciansForums.net
J
Electric pipe bender Hi All, Has anyone got or used one of those new fangled electric pipe benders? Something like the Rotherberg Robend or...
Jerry
J
As above, you really should be capable of dead testing first, as 230V is quite capable of killing or causing bad burns, etc. If you are thinking...
