You can't spur more than one fcu from any socket...? | Page 2 | on ElectriciansForums
Discuss You can't spur more than one fcu from any socket...? in the UK Electrical Forum area at ElectriciansForums.net
Cheshire
Ok guys been asked help mate out but i think he has done his install wrong but as misplace my regs book cant find exact regulations he contravines.
Scenario is this big boiler room and pre existing metal clad sockets in ring final circuit. 32 Amp protection.
He has added 6 FCU metal clad wired in 2.5mm swa. Across 50M of the room at various places as a radial circuit.
Instead of running cable back to the board intends to spur the 6 FCU from the nearest socket of the ring final.
Ive told him im pretty sure you can't spur more than one fcu from any socket.
Am i right ? If so anyone know specifically which reg this is against.
I need to get regs book out but being mainly machine based maintenance guy i dont do that many installs but seems wrong to me.
Thanks guys
What are the 6 separate sfcu for ? Is the total load less than 13a
If yes you got lucky and can feed from the load side of the first sfcu.
If more than 13a is required follows daves advice and create a new circuit on its own circuit
See attached the diagram from the regs
[ElectriciansForums.net] You can't spur more than one fcu from any socket...?
Reply to You can't spur more than one fcu from any socket...? in the UK Electrical Forum area at ElectriciansForums.net
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
