B
Bradzz
Hi all, question im testing an installation that has 1 * 14 way 1* 12 way 1* 2 way 1* 1 way, all of the same incoming phase. 3* meters.
the qeustion is when inputing the Ze and Pfc do i take the highest reading and input this onto each test sheet or do i take a reading from each db and note this down for each db sheet. Say i had a reading from the 14 way Ze of .16 do i note this down on each sheet as they are from the same incoming supply, or do i test each and note down the results for each db on the sheet for that db.
the system is all conduit.
3 phase service head, only 1 phase used, then split at heanley blocks, to 3 * meters., then of to 4 db 1 meter is doubled up, do i code this as this is DNO.
cheers.
cheers.
