Ze and zdb | on ElectriciansForums
Discuss Ze and zdb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
South East Kent
Evening, if say for example I had a ze figure of 1.0 at origin, and I had a Zdb from a sub main to dist board figure of 1.1. To calculate zs is the calculation zs= ze+Zdb+ r1+r2 for the individual circuits.
Many thanks
Yes mate
for a DB supplying a sub board its
Zs=Ze + (R1 + R2sub main) + (R1+ R2final circuit)
the SUB MAIN R1 + R2 IS THE ZDB ALSO fir that board
So measure your Zdb and add to the R1+R2 of final circuit and thats your ZS for the final circuit
Sounds good to me: Zs is the whole impedance, Zdb is the impedance up to the DB where a distribution circuit is involved, Ze is the impedance external to the installation and hence measured at the point closest to the service head. Only thing to watch out for is that you don't count the impedances twice; ie Ze+Zdb. Zdb to my knowledge is the external impedance + the resistance of the distribution circuit conductors (R1+R2). So unless you're going to measure R1+R2 on the distribution circuit (which'd require safely isolating the distribution circuit cable) then add to Ze to get Zdb I'd measure Zdb live then add R1+R2 on the final circuit to get your Zs.Hope this helps.
Hi Guys
Sorry this may be a silly question, but I recently installed a main C/U on a TT system and a sub C/U board in an out building. Both of these systems or on seperate rods and are only connected to there indiviual earth rod, so when i'm trying to calculate the Zs on a final circuit is the sum: R1 + R2 of the supply cable to sub board + Ra of sub board + R1 + R2 of sub board final circiut??
Sorry for this long winded post, your help with would be appreciated
Many Thanks
T&E
Reply to Ze and zdb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
For a new circuit or alteration the dead tests should be done first to ensure it is safe to energise.
For what OCD? There may be other means of over current protection that allow a Zs of0.45 (HRC Fuse?)
