Ze help | on ElectriciansForums
Discuss Ze help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bobby101
so been doing some checking on some notes i dont fully understand why the ze as a max level on a tncs system is 0.35 cause if you apply this to the equation if=Uo/ze it dont work to well it only works if ze is 0.04 thus giving you the 6ka reading rqd or am i not doing this right the reason i want to do it this way iam doing a pir with no power so unable to measure ze any help probably to tired an not really concentrating but any good slap in the face is welcome cause iam doing my nut over this ... ta
with no power, you can only perform your dead testing. why do you want to achieve a fault current of 6kA though?
you could get a value for Ze by enquiry, then calculate the Zs values from R1+R2, but it's far better to do your dead testing, then get the juice on , and then do your live tests.
Reply to Ze help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think I know exactly the stuff you mean - called insulating board (I think) and it's like the stuff you get on pin boards for thumb tacks. I...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
