Ze testing | on ElectriciansForums
Discuss Ze testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
waynelester
hi,i have tested ze on two installation both being tns.the results are 0.08 and 0.12.these figures seem very low for a tns system.are these normal or am i doing something wrong im using a kewtech kt64,,thanks
I have come across Ze values as low as that on a TNS before so I shouldn't worry too much. You are probably very close to the DNO sub.
only query is: are you disconnecting the main earth from the board before testing Ze to eliminate parallel paths?
one other point is are you testing ze or pfc ? with my fluke ze tests between line/earth and pfc between line/neutral, you will get a much lower reading of resistance when set to pfc.
Huh.
PFC.... Resistance???
Are you referring to likely reduced impedance between PFC and PSC?
if you like, The point i was makeing in relation the the op was that my fluke gives a Ohms reading when set to ze and pfc this is obviously measuring a differant fault path and if the op was not familure with testing and or his tester he may be confusing the 2.
sorry dont know what you mean, i have obtained two very low readings for ze on a tns system and was wondering if this was normal or was i testing incorrectly,also the pfc comes out at about 3.2ka which i supose is about right when calculating using ohm law
Reply to Ze testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The issue I was having turned out to be a faulty transformer on the pole 30m away... after hassling the northern powergrid (and having then visit...
The actual listed observations seem easily resolvable, comfortably less than a day's work. The picture of the supply poses a few questions...
