ze testing | on ElectriciansForums
Discuss ze testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
waynelester
hi,i have a question about carrying out a ze test.the supply is a multi head and splits off to supply two properties.the earthing is the same.to carry out a ze test i need to disconnect the earth but i carnt do this without disconnecting next doors as well,any help.thanks
Inform them that you intend to conduct the test, explain risks and ask whether it will be acceptable for you to do so.
If it is acceptable, then arrange time.
If not acceptable, contact DNO and determine Ze by enquiry, make note on PIR.
Reply to ze testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
On the minor works in the brown book it has Zdb
Hi Dave thanks for the info I revisited the premises to change a cooker switch and redone the test from the MET with MET disconnected from DB...
