E
ewillday
Hi all,
I'm testing a 35 year old system, with 11 circuits split across 2 RCDs. 3 of these are lighting circuits 2 come out fine with an IR test but one fails L-N with 0.0 ohms.
This lighting circuit is comprised of 3 ordinary lights, 3 chandaliers and 3 fluourescents. A number of switches including a 2-way that shares the box with an separate lighting circuit (that tested fine).
1. The result suggests a short but everything works as it should.
2. I've looked at everything that is easy to get to (30ft ceillings) and see nothing wrong. The circuit covers 3 floors and 8 rooms so I have no idea which way the circuit runs. Can anyone suggest where the problem may be and a good way of tracking it down?
Cheers!
Ps. I've tested with all lamps removed and all switches open.
Cheers!
