I have found some posts on here about the Zigbee device but i cant find the correct thing online anywhere.
i have installed micro inverters, the I-Manager is too far from the panels when plugged in to the router to pick up a signal so i need to put it closer to the array.
I do not want to run wires so is there a device i can plug into the router and then the monitor device so it connects to the internet?
Please anyone i haven't a clue about these things or the internet and just want to get it sorted for the customer.
Many Thanks
Does the I-Manager have an Ethernet connection only? If your client has wireless you could plug the I-Manager into a wifi bridge repeater, Maplins do a small netgear version for about £50. Does depend on whether the netgear device can still pick up the router's wifi signal from the ideal location you want to put the I-Manager in though. Also, the wifi bridge will need a socket for power. Not familiar with the I-Manager though, sorry
