Hi chaps.
I've got no heating and after a bit of fault finding, I've found there's no switch feed coming from the actuator which then fires the boiler.
The feed side to the actuator is present when you call for heat so couldn't this be linked to send the voltage to fire the boiler and by pass the actuator?
Am I missing something?
