ZS Downlights
N
Nicktric
Hi I know this is a debatable topic looking at other threads so sorry to put the cat amongst the pigeons again... If you want to ZS a light circuit I know you can use Ze + (R1 +R2) but I think it's good practice to Zs to eliminate faults such as connection at CU, switch faults etc. Anyway, with a three lead test no probs with a ceiling rose but with downlights if I don't want to pull every one down because of time and risk the clips damaging the pboard, is the only way a BC adaptor and then wander lead to the cpc in the light switch as opposed to a 2 lead which may trip RCD? What's the quickest/best way?
Hi, metal fire rated SHower ip65 sorry not BC fitting of course but the GU10 pin type. What's the tech term for this type of fitting!? ARe you saying to clip on to the powdercoated can or pull one down for the cpc clip on with a wander lead to do all?
