So the last light on the lighting radial is a pendant but the rose is all painted up .
The previous two lights are those B&Q fittings that takes upto 10 mins to dismantle and 20mins to re-install. the first light on the circuit is a chandalier.
We've all been there, so what did you do to measure (R1+R2) and Zs?
a) Smash the pendant and put up a new one (at your own cost)
b) Spend half an hour or so taking down one of the B&Q fittings (Remember your on a fixed price job so time is hitting your pocket)
c) Take a reading from the pendant, connecting to the earth at the switch (if there is one)
d) Take a reading from the switch using a Nutral from another local circuit to power the meter
e) Declare a limitation that you can't measure Zs for the circuit
f) Somthing else ................................... (please fill in the blank)
