Zs lighting circuit | on ElectriciansForums
Discuss Zs lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
Tonyashby
Hi all how do I test for zs on lighting and where do I do it I know the R1R2plus ze but I can plug my tester in and do it on a ring . So how can I do with tester on lighting prob s dumb question but thank you
Take your reading form the light which you got your highest r1+R2 reading!
Attach your L N E probe to the corresponding connections at the light! And shazzam
Same process as you would with the ring like you've said, however you'll need test probes and to take the shade/cover off the light (preferably the furthest inline) and test at the actual connections.
(Although, from what i gather nowadays in colleges that 'live' testing other than ze and pfc is a complete no-no lol. Bullocks.)
Reply to Zs lighting circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
  • Locked
Thread closed.
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
