Zs reading across RCD | on ElectriciansForums
Discuss Zs reading across RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
beaver74
Hi all
with a heathy ZE ..22 on a TN-s system i had a R1+R2 of .40 oh my suprise to find that the Zs was 1.01at the furthest socketrechecked my ZE.22??
rechecked ZE from out going terminals of RCD .60 has any one else found this
ps i realise that this reading is fine as RCD protected just wondering
Hi all
No trip or D lock setting on the meter by any chance
Ya I've seen this too, several times. But sometimes this internal resistance of RCCB is really high. Mostly it's about 0.20ohm to 0.30ohm but in some occasions it's 0.50~0.60ohm. RCBOs have less in my experience. I mentioned this issue in IET forum couple of months ago and outcome was it's normal, nothing to be worry about. But is this this really ok or not, you should judge yourself. :)
Ya . But is this this really ok or not, you should judge yourself. :)
as for the reading no problem in the higher Zs as it is protected by the RCD .but i was more concerned about the fact you can have such a differance acroos what is in effect a swithed set of contacts
Reply to Zs reading across RCD in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
Duh!!! Just re-read Op's original post, it was converted to a RFC!
