Zs Test | on ElectriciansForums
Discuss Zs Test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Zs is carried out at the end of a cct
Ze is carried out at the board
Zdb is carried out at dis boards
HTH and no need to shout lol :D
Agreed, but it is generally called Zdb, you'd call it Zs on the test results for the board that is feeding the sub main.
Yep, agreed too as a submain is not a final circuit.
Seems we all agree, all Im saying is that a sub main has a Zs and not a Ze in reply to Wallyanker's post.
You can call it Zdb or Zebedee if you want, but it's still Zs.
Reply to Zs Test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
Hi Dave thanks for the info I revisited the premises to change a cooker switch and redone the test from the MET with MET disconnected from DB...
