Zs tripping RCD on no-trip setting | on ElectriciansForums
Discuss Zs tripping RCD on no-trip setting in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Grant Naylor
Practicing with my tester so I wanted to measure Zs on my cooker (At least I now have clean floor behind the cooker ;)).
The cooker is on its own M6 Type 1 - 32 A MCB. It is protected by an 80 A / 30 mA RCD. I have tested the RCD and it is functioning correctly (x0.5=NO TRIP / x1=27ms / x5=11.1ms). The RCD does not trip when either the cooker or socket are in normal use.
My cooker is wired to an isolator with a socket outlet, then down to the cooker connection accessory.
If I take Zs at the socket outlet using the no-trip setting it reads 0.22Ω
However, if I try and take Zs from the cooker connection accessory the RCD trips out?
I haven't done any other tests. I know sometimes RCDs can trip even on no-trip setting but this puzzled me as the socket is OK.
What am I doing wrong?
If you have the Dilog 9083p some of these are faulty and sometimes trip RCBO's and RCD's when doing ZS
You will have to get intouch with the manufacturer.
Having read this post again, I would advise to do an insulation test at the cooker connection, as you could have low readings, which is causing the meter to trip the RCBO
IR gives >999 MΩ from both the plug socket on the isolator and the connection accessory.
I guess I need to try a Zs on full charge and see if this makes a difference.
Reply to Zs tripping RCD on no-trip setting in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
