zs=ze+r1+r2 | on ElectriciansForums
  • Thread starter ab1978
  • Start date
  • Replies 5
  • Views 4K
Discuss zs=ze+r1+r2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
ab1978
when we measure zs on a circuit and then calculate to back up result using above formula do you get sometimes a different result to your measured zs using earth fault loop meter?
results are within the guides but can be .10ohms - or+ or more out?
I had a strange thing with zs readings today.
The system was a TT and the ZE reading was 24 ohms, r1/r2 was 0.3 but measured zs was 29 ohms, apparently the RCD can cause this
Nothing unusual about this - so long as your measured Zs` are lower that is!
Parallel paths back to earth often reduce a calculated reading to a lower, measured figure. Otherwise, temperature variations can alter your readings either way.
Providing your numbers are within Max Zs allowed then all fine & dandy, so don`t be tempted to adjust back to what Ze + ( R1+R2) works it out to be - `doctored` readings are obvious to a overviewer...:eek:
If your measured readings are ok, then they`re ok. Period :)
Nobody has mentioned contact resistance yet. Or the difference between a DLock measurement and a straight measurement.
I can't actually remember the last time my figures added up.
Sure, you`ll always get skewed readings on a `No Trip` setting or similiar methods to keep the RCD in. They`ll increase your Zs readings by varying degrees.
As you re-affirmed tho, measured v calculated are often not that close - & the main point is not to try to get them to add up - by all means do the equation to check measured value makes sense, but if it does then have confidence in your test gear & record the result it gave you.
You also need to be aware that both Zs measured and Ze measured are perfromed using mains Ac voltage at current upto 25A D lock and 15mA notrip, where as the r1+r2 are measured using a dc tester whose output voltage is 4v to 24V at only 200mA as a result trying to add an AC result and a d.c result will result in an error/difference in reading.
Reply to zs=ze+r1+r2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
