Currently reading:
Car Battery Alternative
Discuss Car Battery Alternative in the UK Electrical Forum area at ElectriciansForums.net
grokuk
Hello All,
I'd appreciate some advice and your patience at my lack of knowledge of things electrical. The situation I have is I need to run a diesel pump that is designed to run off a standard car battery but I'm not using it to pump diesel or do it anywhere near a car. I would like to have some form of transformer to power it off the mains.
I have a little 12v 0.5amp transformer for light electrical items which clearly doesn't do the job - I'm assuming it's the very low ampage that's barely turning the pump over. I'd really appreciate some recommendations on the kind of transformer I'd need to essentially reproduce the output of a car battery.
Many thanks.
hello all,
i'd appreciate some advice and your patience at my lack of knowledge of things electrical. The situation i have is i need to run a diesel pump that is designed to run off a standard car battery but i'm not using it to pump diesel or do it anywhere near a car. I would like to have some form of transformer to power it off the mains.
I have a little 12v 0.5amp transformer for light electrical items which clearly doesn't do the job - i'm assuming it's the very low ampage that's barely turning the pump over. I'd really appreciate some recommendations on the kind of transformer i'd need to essentially reproduce the output of a car battery.
Many thanks.
you need to find out what current the pump draws. Then you can determine the size of power supply you will need. POST YOUR LOCATION AND ONE OF US MAY BE CLOSE ENOUGH TO ADVISE.
I'm pumping wine from one very large barrel to another. The pump details are:
Test Voltage: DC 12V
Motor Racing Speed: 8500r/min
Motor racing current: 0.3A
Pump running current largest :6.4A
Flow rate: 30L /min
Pressure head: 2.5M
If that helps. Not sure what's meant by the load?
'Thinking outside the box' is a nice cliché for a job interview or an episode of The Apprentice but can cause problems when it comes to electricity.
What is it that you're actually trying to do? Chances are someone has done it before and there is already a way of doing it without you having to guess.
Typical portable 12V fuel transfer pumps require something in the order of 15-25A; post the spec of your pump.
The cold cranking amps needed to turn over and start a Diesel engine are quite high.
Probably be cheaper to use a battery with a trickle charger.
He's not starting a diesel engine. He's running a pump. And not for pumping diesel anyway. Daz
Flow rate: 30L /min
Pressure head: 2.5M
No your not!!!... unless this wine is going for waste, food and beverage pumps have strict guidelines to meet and you cannot take any old pump and decide to use it no matter how much you clean it up first or even if its new, unless you wish to risk making all you customers very ill, I would purchase the correct equipment no matter how expensive it may be, otherwise you may face some criminal charges for breaching food and beverage hygiene regulations, specifically the equipment used in its making and storage.
To note here, Wine and similar is acidic and pumps requiring a specific stainless steel grade of 316 or higher, also the seals and all associated hosing etc has to be graded for use with wine or chemical reactions may occur leading to contamination, even if this is just a one off transfer, using the wrong equipment can ruin the whole lot taste wise or make it not suitable for consumption due to chemical contamination.
A little Gobsmacked here tbh, unless you can correct me, but as I read it you are going to pump wine for eventual consumption using a diesel pump, have I got that correct?
Cut out all the tedious brewing malarkey and just drink the diesel! Not all that different, comes in red and white versions just like wine, in my marine engineering days I must have had a few glasses of it.
On another note that's weird, I never saw the post* about the application and pump rating which is why I asked, but it's a bit academic now as there seems to be a better option that won't have non-food-grade lubrication etc like a diesel pump.
*I guess it was waiting for moderation, so not that weird then.
Yes was in the Mod Queue for 4hrs... sometimes we are all busy working our butts off :4:and we get the odd post that stands in the Mod Q longer than the norm' :uhoh2:
pete999 should be able to adjudicate here. he drinks that french coats de roan muck. just like red diesel.
The beauty of diesel is that one mouthfuls bouquet and taste lasts for days. :)
Flow rate: 30L /min
Pressure head: 2.5M
Pull the PSU out of a dead PC, Google will tell you how to turn in on in the absence of a motherboard/on/off signal = 12v @ more than enough amps.
I hope this is homebrew only.
Reply to Car Battery Alternative in the UK Electrical Forum area at ElectriciansForums.net
