Discuss Drum Hanging Down in AEG L75670WD Washer Dryer in the Electrical Appliances Forum area at ElectriciansForums.net
The drum is hanging down. I googled the problem and its seemed that the bearing needed to be replacement. However, I am unable to find this part. Is this because its called something else in this model?
The whole drum assembly, including the outer tank, is held steady by shock absorbers at the bottom, which wear allowing the drum to shake about.
There are also springs at the top holding the drum assembly up - are they OK?
From personal experience, these things are not always the easiest to replace, and the sharp metal edges in the machine can bite you!
Click below on "functional parts":
Before buying anything make sure of model number etc.
Reply to Drum Hanging Down in AEG L75670WD Washer Dryer in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
Hello, I have an all-in-one washer/dryer unit and it is giving me error codes. I have the manual that describes how to test the various...
I am totally new to fixing things but with the help of YouTube I think I've diagnosed my tumble dryer, now, I'd just like to know what others...
Hi, my CDA FWC303 wine fridge is knackered. The compressor doesn't start and I've traced it to the PTC which I plan to replace and have identified...
