Currently reading:
hand tools when your old and falling apart
Discuss hand tools when your old and falling apart in the Electrical Tools and Products area at ElectriciansForums.net
richy3333
Mentor
Supporter
Hi All.
Hoping for some advice please. I've severe arthritis in the hands (all three :flushed:) A large dollop of osteoarthritis but I'm also being investigated for rheumatoid arthritis too (due to swelling in fingers, redness and burning sensations). I have difficulty typing, opening jars - anything a 90 year old could show off and do! I'm principally struggling with screwdrivers. The physio suggested looking for screwdrivers with fat handles as they thought it would alleviate some pain.
My left knee is jiggered, I'm down to bone grinding on bone, I've always worn knee pads, kneeling mats etc.
Are there another suffers out there and if so do you have any tips that might help (short of retiring, which I can't do). Not really looking for sympathy (not get it on here anyhow ;)) but any tool tips or work arounds etc.
Many thanks.
I have seen some "electric screwdrivers" that are designed for terminals, so they have a very limited torque and allow you to speedily drive the terminal closed, etc, but without that damage impact drivers cause.
You can also get some drivers that take 1/4" extensions so a T-bar on top of the screwdriver-like handle could allow hand torque without too much gripping force.
If anyone knows what screwdrivers are out there, it'll be @Dustydazzler
If you are looking for something with a bulky / large round grip look up Vessel Ball Grip
For plate screws etc these would be useful, but not for much else as you need to change driver to tighten anything.
I can't help thinking about the big, dumb looking Klein driver that's popular in the states as it looks as though the grip is very wide - might be just images though, so wouldn't recommend anyone buys it on the basis of my musing.
Looked at the ratchet version of that on Amazon not two minutes ago and didn't realise there were others available.
I have an old RS ratchet driver (No. 2 pozidrive) and it is probably my most valued screwdriver! These days folks your power tools for most things, but in the olden days this saved a bit off effort and does not remove the finer manual control of a traditional driver.
The old fashion Wiha ProTurn were lovely old Drivers as well with a massive handle grip. Sadly no longer made
I used to like the old Stanley Yankee, long before pozi's or battery drills/drivers. It's hidden away somewhere. That used to save some time first first fixing.
Don't think it would be much good for richy, though...could be a bit vicious, that thing.
I have mild arthritis in my right knee, lower back and hands. It all kicked off during Covid when i was working flat out, as holidays were too risky and my clients were still active. Shortly after an intense project i was forced to take 2 weeks off as my knee was so swollen i could not get in and out of the vehicle. My Xrays showed it was not a total loss so not ready for new joints yet but since then i have done a number of workarounds and since then my back and knee are manageable without pain killers.
Here is my new regime:
1. Break up repetitive movements like, climbing ladders or even climbing in and out of a scissor, i.e. Last job involved a high number of warehouse lights - 8M up. Normally i would prep the lights in one go and then hang them to reduce scissor battery drain. Now i will break up the prep work which reduces pain in my hands and when i am in the scissor , i stay in the scissor - my assistant passes stuff to me so i dont need to get in and out.
2. Reduce lifting to an absolute minimum, i use clients pallet trucks to move tools and stuff around and make many light journeys instead of trying to carry a heavy load.
3. Ladder work to an absolute minimum, a scissor although not cheap, is so much better. A job i would have previousy tackled with a ladder, i just dont do.
4. Again on repetitive work, like multiple cable terminations, i split it up with other work, it does take a conscious effort to walk away from another 20 odd terminations but i pull a few cables, then terminate, then pull a few more etc.
5. Have a holiday after a big job.
6. Monthly appointment with Osteopath to keep my back from locking up
7. Occassionally take 600mg of Ibruprofen to get me through the day but its rare and not recommended for long term use.
8. Keep mobile, my Osteopath recommended walking for my back, it does help.
9. Also i have found my muscles are now too strong for my joints so i dont try and push my muscles to the max.
Appreciate you are suffering much worse as i am not quite bone on bone, but i have found the nature of our work creates a repetitive action which, for me, causes inflammation, and hence loss of movement and pain.
Hope this helps.
In my view, I think you need a new doctor. You need to address the health issues you have. Clearly that is not happening with your current health care regime. Bottom line, improve your health, not your screwdriver.
The Bosch Go2 electric screwfriver is a fat handled unit. It also has variable torque, so is great for faceplate screws when set at a low level. You can turn up the torque for other work or lock it off. It saves time and obviously you don't need to use your wrists as much as with a normal driver.
Cheap dog walking grade small tennis balls with a hole in them to slip over handles, same deal using pipe insulation.
For the record, as a tennis player, I always recycle my tennis balls by giving them to my dog-owning friends...and I mean quality balls, not cheap crap! These used balls, from a premium maker, last at least 3x as long as the cheap ones! Once the dogs get them, we're talking at least 3 minutes!
Here's a quiz!
If you can name the tennis balls I use, I will donate £10 to RNLI, so get guessing!
Here's a quiz!
All the Slazenger tennis balls used to be made not for from me in a factory at Barnsley. They made them there for many years. Closed now unfortunately.
I have heard others with knackered knees suggesting sitting on toolboxes rather than kneeling where possible.
I was considering the Wiha speed e 2 as oddly my elbow hurts after using a screwdriver for too long.
Aeroplane
Art engo
Boris Becker
Bridgestone
Crane Sports
Diadora
Donnay
Fischer
Hema
Iso-speed
ITF
Kaiser
Pro Kennex
Pro Penn
Pro's Pro®
Shamp
Singa
Sportastic
Srixon
Star
Tecno Pro
Teloon
Topspin
Tyger
Völkl
Yonex
Karakal
Teloon
Kason
Adidas
Unique
Pro's Pro
K3
Wilson
Penn
Tecnifibre
Prince
Dunlop
Slazenger
Head
Babolat
Gamma
Tretorn
Fischer
Nassau
Pennsylvania
A. G. Spalding & Bros. (97 items)
A. J. Reach Company (0 items)
A. W. Gamage Ltd. (3 items)
A. W. Phillips, Ltd (11 items)
A.C. McClurg & Co. (2 items)
Abraham & Strauss (1 item)
Accura (0 items)
Ace (5 items)
Adidas (1 item)
Alex Taylor & Co. (1 item)
All-Pro (1 item)
Allo (1 item)
AMC Amcrest (5 items)
American Sporting Goods (1 item)
Andia Progress Co. (1 item)
Anglo-Scandinavian Corporation (1 item)
Anker Chemical Industries Co. (1 item)
Apollo (1 item)
Aqua-Leisure Industries, Inc. (1 item)
Army & Navy Stores, Limited (1 item)
Artuff (1 item)
Atp Tour (0 items)
Avon India Rubber Company, Ltd (1 item)
Ayres, F.H. Ayres Ltd. (4 items)
Azrak-Hamway International (2 items)
B. F. Goodrich (0 items)
Babolat (3 items)
Baileys (0 items)
Ballco Products, Inc (1 item)
Bancroft Sporting Goods Co. (22 items)
Banks (1 item)
Barnet Glass Rubber Co. Ltd. (4 items)
Barville (1 item)
BCM/Hermetic (1 item)
Benjamin E. Pascolat (1 item)
Bentley's Sporting Goods Limited (3 items)
Bernard Young & Co., LTD. (3 items)
Best Sporting (1 item)
Bill Tilden (2 items)
Bilt-Rite Sporting Goods Co. (1 item)
Borden (0 items)
Borneo-Sumatra Trading Co. Inc. (1 item)
Borsumij Wehry (1 item)
Bridgestone (9 items)
British Sporting Goods (1 item)
Browning (1 item)
Buckingham Sports, Ltd. (2 items)
Butchart Nicholls (1 item)
Calgon (1 item)
Cambridge (1 item)
Campbell Manufacturing Co. LTD (4 items)
Campbell's (0 items)
Canada Needle & Fishing Tackle Co., Ltd. (1 item)
Canadian Tire Corporation, LTD (2 items)
Canon (1 item)
Caprico (2 items)
Carnaby Sporting Goods (0 items)
Carrera International Corporation (0 items)
Champion (2 items)
Chemold (8 items)
Chicago Sports Equipment (1 item)
Christian Dior (1 item)
Classic (1 item)
Club (2 items)
Coast to Coast Stores (2 items)
Coca-Cola (5 items)
Color Seam Enterprises (1 item)
Compass Co., The (0 items)
Contender (0 items)
Continental (6 items)
Continental Sporting Goods (7 items)
Cortland (4 items)
Court King (4 items)
Court Pro (1 item)
Cragstan (1 item)
Cross Court (1 item)
Crown Manufacturing Company (1 item)
Crown Sports Inc. (4 items)
Cummings Brothers, The (1 item)
Cutino Company, The (1 item)
D. W. Granberry & Co. (0 items)
Davega (3 items)
Davidoff (0 items)
DeLacoste Et Cie (1 item)
Demon (1 item)
Deportes Lincoln S.A. (1 item)
Donnay (3 items)
Draper-Maynard Co (The) (4 items)
Dreier Company (The) (0 items)
Dunhill Sports LTD (2 items)
Dunlop Tire & Rubber Corp. (152 items)
Durus (0 items)
E & L Products Mfg. Co (7 items)
E. J. Riley, LTD (0 items)
Eagle (1 item)
East London Rubber Co. LTD (0 items)
Ecsport Sales Corporation (1 item)
Elgee (1 item)
Elite (0 items)
En-Tout-Cas Co. (The) (1 item)
Equator Import Company (3 items)
ERKA Handelsgesellschaft mbH (1 item)
Eugene B. Baehr and Sons (1 item)
F. A. Davis, Ltd (2 items)
Falcon Sporting Goods, Inc (0 items)
Fatra Napajedla (1 item)
Faultless Rubber Co. (The) (2 items)
Feltham's (0 items)
Firestone (3 items)
Franklin Manufacturing Co. Inc (1 item)
Franklin Sports Industries, Inc. (1 item)
Fred Perry (4 items)
Free Former Sports Products (1 item)
Fu Jen Chemical Co., Ltd. (0 items)
G. Lanfranconi S.R.L. (0 items)
G. R. Adams Ltd. (2 items)
Gabri-Torino (1 item)
Gamma Sports (2 items)
Garcia Ski & Tennis Corporation (The) (1 item)
General Sportcraft Co. LTD (13 items)
General Sports (2 items)
General Tire & Rubber Co. (The) (7 items)
Geo. G. Bussey & Co. (1 item)
George Spencer, Moulton and Co. LTD (8 items)
Gimbles (1 item)
Golden Crown (5 items)
Golden Eagle (0 items)
Golden Streak (1 item)
Golden Team (1 item)
GoldSmith - P. Goldsmith Sons Inc (6 items)
Goodall Rubber Co. (3 items)
Goodwin Sporting Goods (4 items)
Grands Magasins du Louvre (1 item)
Grays of Cambridge (4 items)
Grenvilles LTD. (0 items)
Halex (1 item)
Hanil (0 items)
Harburg-Wien (1 item)
Harrods (1 item)
Harry C. Lee & Co. (4 items)
Hawthorne (3 items)
Head (0 items)
Henley's Tyre & Rubber Company, LTD (1 item)
Hi-Tens (1 item)
High Skore (2 items)
Holiday (3 items)
Holmar International Corp. (2 items)
House of Sports (1 item)
Hugo Boss, AG (1 item)
Hunt (0 items)
Hutchinson Gommitalia Spa (1 item)
India Rubber, Gutta Percha & Telegraph Works Co Ltd (The) (2 items)
Inter Sport (1 item)
International Nineteen, Inc (3 items)
Interstyle International (1 item)
Ivor Williams (1 item)
J. B. White & Co. (1 item)
J. C. Higgins (10 items)
J. M. MacDonald Import Co. Inc (2 items)
J. Price [Bath] Limited (3 items)
Jack Summers & Co. LTD (1 item)
Jacques (1 item)
Jas. Lillywhite, Frowd & Co. (7 items)
Jelinek Sports Limited (4 items)
JMC (1 item)
John Holden LTD. (1 item)
John Wisden & Co. Ltd (9 items)
Johnny Walker Sporting Goods (1 item)
Jollette (2 items)
Josephs Sports LTD. (1 item)
Justen (2 items)
Kabet (1 item)
Kassnar Imports (1 item)
Kawasaki Racket Co. Ltd. (1 item)
Keynote Sports (1 item)
King Athletic Goods Company (7 items)
Kings Court (1 item)
Korvettes (2 items)
Lacoste (1 item)
Leda (1 item)
Lenglen's Ltd. (1 item)
Lew Hoad (1 item)
Links of London (1 item)
Lloyd Budge Century Country Club (1 item)
LTC (1 item)
George MacLellan and Company LTD. (1 item)
M. Sharf & Co., Inc (1 item)
MacGregor (22 items)
Macys - R. H. Macy & Co., Inc. (10 items)
Madison (0 items)
Mag (0 items)
Major International (3 items)
Manhattan Novelty Company (1 item)
Marco (1 item)
Martin (Fred Martin Agencies) (0 items)
Marvel (0 items)
Maxima (0 items)
May Company (The) (1 item)
Meier & Frank Co. (17 items)
Mercur (1 item)
Mick House Co. LTD (1 item)
Midland Sporting Goods (1 item)
Mil (1 item)
Mitchell and Co. (0 items)
Montgomery Ward (11 items)
Montrose (1 item)
Mor-Flite (1 item)
Muller (1 item)
Munro Sports Inc. (1 item)
Nastys Fess (0 items)
National Recreation Products, Inc (2 items)
Neiman - Marcus (1 item)
Net World Sports Ltd (2 items)
Nimble (Dunlop) (1 item)
Nintendo (0 items)
Nobility (1 item)
Norvell-Shapleigh Hardware Company (0 items)
NSG National Sporting Goods (4 items)
Seh Bang Products Co. LTD / Nassau Co., LTD (7 items)
Official (1 item)
Offizieller (1 item)
Ol' Reliable (1 item)
Olympic Sporting Goods Co., Inc. (2 items)
Optimit Odry (10 items)
Ormiston Rubber Co. PTY LTD (3 items)
Overman Wheel Co. (0 items)
Pace Setter Marketing (3 items)
Pacific Coast Racket Co. (1 item)
Pacific-Entermark GmbH (1 item)
Palma (0 items)
Paramount Sports (1 item)
Peck & Snyder (0 items)
Peerless Sporting Goods (1 item)
Pennant (1 item)
Pennsylvania Rubber Company (85 items)
Pennsylvania Sporting Goods (2 items)
Peradin Works (2 items)
Perfection (1 item)
Phoenix (0 items)
PIC - Precise Imports Corporation (1 item)
Pioneer (2 items)
Pirelli (22 items)
Play King (1 item)
Playmaker (0 items)
Po-Do (1 item)
Point (1 item)
Pony (1 item)
Pope and Smith Ltd. (1 item)
Prep (0 items)
Primo (2 items)
Prince Manufacturing Inc. (1 item)
Pro (1 item)
Pro Kennex (4 items)
PZM Industrial (1 item)
Rawlings Sporting Goods Company (15 items)
Red Line (1 item)
Red Triangle Factory (0 items)
Regent Sports Company (20 items)
Rexall Drug Co. (4 items)
Rhody (1 item)
Robin Soderling (2 items)
Ronmark (1 item)
Roos Brothers (1 item)
Royal Ace (1 item)
Royal Court (2 items)
Rucanor (Rubber Canvas Organization) (2 items)
RW (0 items)
S. S. Kresge Company (Kmart) (1 item)
Samwha Rubber Co. (3 items)
Schmelzer's (0 items)
Seamco (2 items)
Seamless Rubber Co. (6 items)
Sears Roebuck and Co. (24 items)
Seaway Products (1 item)
SECO Sports Equipment Corporation (4 items)
Sentra (1 item)
SET - STOLLE EMERSON TENNIS CO., INC. (0 items)
Setico Import Co. (0 items)
Shanghai Tennis Ball Factory (7 items)
Showa Rubber Co., Ltd. (3 items)
Singa (3 items)
Slazengers Ltd (107 items)
Snauwaert (1 item)
Spartans Industries, Inc. (2 items)
Sport Scheck (1 item)
Sportcrest (2 items)
Sportrite (1 item)
Sports Action (0 items)
Sportsotron Inc. (1 item)
Standard Harburg-Wien (0 items)
Stomil (4 items)
Stuart Surridge & Co Limited (1 item)
Sumitomo Rubber Industries, LTD. (16 items)
Sun Coast Corp. (Acme) (0 items)
Super Pro (1 item)
Swift Flyte (0 items)
T. Eaton Company (The) (2 items)
T.M.C. (3 items)
TAICO The American Import Co. (4 items)
Talisman (3 items)
Team Nicola Pietrangeli (4 items)
Tecnifibre (0 items)
Ted Williams (2 items)
Telnor Systems Corp (1 item)
Tempo Sports Inc (2 items)
Ten Pro International (2 items)
Tenn-X, Inc. (1 item)
Tennex (1 item)
Title Products Ltd. (3 items)
TOA-Strings Co. Ltd., (1 item)
Tobishi (1 item)
Tom Stevenson (Sports) Ltd. (3 items)
Top Score (1 item)
Top Speed (1 item)
Topps (1 item)
Tornel (2 items)
Town and Country Games Limited (1 item)
Tram Flite (1 item)
Treasury Drug Division of JC Penney Co. Inc (1 item)
Treasury Drug Division of JC Penney Co. Inc. (0 items)
Tretorn (12 items)
Trigema (0 items)
Trio Sporting Goods Mfg. Co. / Hollander (8 items)
Triumph Manufacturing Company (0 items)
Tru-Play (1 item)
Tryon Athlete Dept. (1 item)
Tweedies' Sports Centres Ltd. (1 item)
United-Rexall Drug Co. (0 items)
University (2 items)
Unknown (3 items)
UPA International (1 item)
VEB Gummiwerke (4 items)
VEB Reifenwerk Heidenau (1 item)
Vermont Sports (2 items)
Verve (0 items)
Victory (1 item)
Virginia Slims Tennis (1 item)
Volley (1 item)
Vornado, INC. (1 item)
Vredestein (1 item)
F. W. Woolworth Co. (1 item)
W. J. Voit Rubber Corp. (5 items)
Walgreen Co. (6 items)
Walker International (3 items)
Walter Precision Italiana (WIP) (1 item)
Welcom - Williams, Ellis & Co. LTD (3 items)
Western Auto (1 item)
Williams & Co. (1 item)
Wilson Sporting Good Co. (0 items)
Wilson Sporting Goods Co. (100 items)
Winchester (1 item)
Windsor (3 items)
Winn Sports Corp. (2 items)
Wm. Hailwood Sports Depot (1 item)
Wonderful (1 item)
Woodward Sports (1 item)
World Wide Distributors, Inc. (0 items)
Wright & Ditson (31 items)
Yonex (1 item)
Young (2 items)
Zayre Corp. (3 items)
1955 Biddle Purchasing Corp. (10 items)
Well it certainly another good example of the number of manufacturers coming out with a load of balls, these days!!
I'd second both of these suggestions. Vessel make very good screwdrivers and the ball grips are easy on the hands although the range is limited. I also use the Bosch GO2 (avoid the original Bosch Go) and it's pretty good with the variable torque setting and obviously you can use any make and type of bit with it..
I have one ordered so should get it Monday, will report back how useful (or otherwise) it is.
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a middle locked position (handy for adjustment use), but otherwise does what it says. The hex bit holder has a good positive retention of bits and the sleeve to operate that could be used as a guide with your other hand if needed as it rotates freely.
Holding it suggests it would be easier to apply torque if hands sore than a conventional driver, but if really troubled with arthritis then repeated wrist action might not be great, compared to a low torque power driver.
Reply to hand tools when your old and falling apart in the Electrical Tools and Products area at ElectriciansForums.net
