Currently reading:
SSE Temporary Seals
Discuss SSE Temporary Seals in the UK Electrical Forum area at ElectriciansForums.net
Tuttle
Does anyone know if SSE still provide temporary seals for CU changes, and if so where I can get some from / what their procedure is?
I've found links to SSE information on threads in this forum and others, but none of the links seem to work anymore.
you can buy them on ebay and the tool apparently
Thanks ayjay. I've actually got some from ebay and that's what I normally use when a seal is missing, just for safety really, but they're nothing like the real DNO seals. I had heard that SSE can provide temporary seals, you notify them when you've fitted one and they they supposedly come along later and reseal it properly. i just thought that if they had put a procedure in place then perhaps I'd try and use it.
You need to call them At castle mallwood they issue you with a Sticker to put over the fuse after you have removed seals then notify them.
They will post them out to you, they check you are niceic or equivalent first
You'll probabaly need to take a trip to the SSE depot in Slough and take your scam membership card with you!
Reply to SSE Temporary Seals in the UK Electrical Forum area at ElectriciansForums.net
