- Reaction score
- 2,119
The main switch isolates the other two basically the same as a dual rcd cuquestion! are the 2 additiona Switched fed through the main one, or are all three connected parallel?
Discuss 2 x Main Switches in on consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Cheers, it does make sense, but it is not incorrect to connect them in parallel right? Or is there a requirement to have one main disconnection point in the CU?The main switch isolates the other two basically the same as a dual rcd cu
The actual main switch must isolate everything.Cheers, it does make sense, but it is not incorrect to connect them in parallel right? Or is there a requirement to have one main disconnection point in the CU?
I was told that for years, however my house has a few, the DC isolators, the UPS isolator, the DNO isolator etc. And at work one building has at least three DNO supplies, maybe four.You should have one main switch which isolates the whole installation.
If a board is marked up as having a main switch then it should isolate that DB so that there is nothing live after that main switch.I was told that for years, however my house has a few, the DC isolators, the UPS isolator, the DNO isolator etc. And at work one building has at least three DNO supplies, maybe four.
Reply to 2 x Main Switches in on consumer unit in the UK Electrical Forum area at ElectriciansForums.net
