Search the forum,
Discuss 220v attic conduit question in the UK Electrical Forum area at ElectriciansForums.net
Hello all, new here. In the near furture i want to install an electric tankless water heater. I would do gas but i only have electric in my home after moving. I will be hiring an electrician to do the wiring. Its only 30 feet from electrical box to water heater location and i will need a double 40amp breaker, wich i already installed. I also have a roll of 6 ga wire from doing a project on my previous home. Will i need conduit in the attic for the wiring? I'm in Arizona.
thanks
thanks
Sorry for the late reply but if you are installing it in your attic you shouldn’t have to install it in conduit. Make sure it’s stapled every 4 feet. Please don’t nail the staples in so hard it touches the cable. Good luck and welcome to the forum.
Do you have capacity to handle a tankless? Some models require up to 3-40A feeds to supply them, which could mean a upgrade of the service, I hate propane but I would consider it.
Reply to 220v attic conduit question in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
I am thinking of getting an Electric vehicle. The only way for it to be realistic is to home charge. The problem, I have a fuse box no breakers...
Hello, Question is regarding a recently purchased property in Central Texas, which includes a 27KW tankless electric water heater. It is four...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
