Discuss 240v outlet voltage drop under load in the DIY Electrical Advice area at ElectriciansForums.net
windhamb
I have a 3 prong 240v outlet for a dryer that reads 240v across both legs and 120 across the ground. When I turn the dryer on and have the multi meter to the ground and a hot leg it shows 120 but if I switch it to the b leg and ground it shows 40 then climbs up slowly to 120. The ground is new and goes to a new ground rod outside as well. I verified it isn't the dryer by plugging it into a different 240v outlet and it works fine. I'm stumped and looking for any help.
Reply to 240v outlet voltage drop under load in the DIY Electrical Advice area at ElectriciansForums.net
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I have a portable fridge in the caravan. It errors when connected to the fridge circuit in the van but does not error if I connect it directly to...
40 year old square D QF1TF long span top fed. I turned off 30 amp double pole to water heater and still had a closed circuit, then turned off the...
