Search the forum,
Discuss 3 gang 2 way smart wifi switch confusion in the UK Electrical Forum area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones)
One of the 3 switches, switches the loft light on/off
The second one switches a motion sensor outside which is connected to two up/down lanterns on and off plus they have override built into them so they can stay on permanently.
The third one does the same as the second one but for a lantern at the front of garage
If they are dimming smart switches, probably not
if they are relay type smart switches then probably yes.
you may well require a N at the switch position
Smart switch 2-way operation is often achieved by the second "2-way" switch actuating the first "2-way" by RF (the first actually doing the switching), not by physical connection, so although they can provide 2-way functionality, they are not necessarily actual wired 2-way switches. So if you have 3 wires at the switch, you may not be able to do this with the same hard wiring, and a little thought will be required. Check the physical connections of the 2-way smart switch you are proposing to buy, and how it relates to the circuit you have.
Reply to 3 gang 2 way smart wifi switch confusion in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
I genuinely can't find a 3 gang 3 way black smart light switch - any ideas where I can get one from? Seems to be hard to get hold of?
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
