Search the forum,
Discuss 3 Phase Billing in the Electricians' Talk | All Countries area at ElectriciansForums.net
G
Graeme Harrold
Got a query about how a 3 phase domestic supply is charged by the supplier. 3 phases enter the meter (digital), does this work out the actual energy used or does it mesure the highest phase and read accross the other two??
basically its a domestic supply with inballanced loads. The sockets and lighting are split off 2 phases with off peak storage on the third, not ideal. Im almost positive the customer would be far better off with a single phase supply. Any help on this is appreciated.
Regards
Graeme
Hi Graeme
The phases are metered individually in the meter as you push the button you see L1 L2 L3 then they add all 3 together to give you the bill if in doubt enter 3 phase meter in the search engine or contact DNO and they will also help but should also be marked on your bill
Regards
Kung.
Regards
Graeme
Ooooops should have been non-digital, but shouldnt make a difference. just 2 counters, 1 for day and the other for night..........
Reply to 3 Phase Billing in the Electricians' Talk | All Countries area at ElectriciansForums.net
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
