Search the forum,
Discuss 3183yag cable 1.5mm flexible for lighting ring in the DIY Electrical Advice area at ElectriciansForums.net
SiJohn
Hello all, I think I might have done gone and ducked things up.
We got a timer frame single story extension put on( 35sqm)
For the Lighting circuit i used 3183yag multi strand flexible 1.5mm 3 core cable. Should I have used single strand?
If this is linked to your other thread you need to asking your electrician.
Hello , he said it would be okay.
If he has said it would be okay what is the problem.
When i re read the spec from screw fix it did not say if it was suitable for lighting rings.
I ( probably incorrectly) assumed that 1.5mm would suffice regardless if it was multi strand flexible as opposed to single strand.
Reply to 3183yag cable 1.5mm flexible for lighting ring in the DIY Electrical Advice area at ElectriciansForums.net
Hello and good morning all. I am putting in a first fix on a small extension. It will have its own fuse board coming from the main house. I plan...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
I would like to reuse a 10mm cable to provide a ring circuit in an area. The cable is currently used for an electric shower, still connected at...
Hi guys, I'm trying to find a definitive answer on the use of 1.5mm 2C+E for power points in a transportable structure which is fed by a 15A inlet...
