Discuss 3A fuse instead of 13A? in the DIY Electrical Advice area at ElectriciansForums.net
dorsel
Hello. I live in a new build house with a separate garage. The garage is connected to RCD in the house to a 16A circuit breaker. The cable from RCD leads to a 13A FCU and from there separately to a double socket and light switch. As it's radial circuit I was planning to add another socket off the existing one and add some lights. I noticed there is only a 3A fuse in the fuse box, should there be a 13A instead? I want to install tumble dryer in the garage and build a small workshop (no power hungry tools).
The 3A fuse is there to protect the current lighting. For additional power you connect from the non protected 3A fuse side.
Reactions: DPG
Reply to 3A fuse instead of 13A? in the DIY Electrical Advice area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi I have a Corby 7700 trouser press it is a 220w model, 3 years 10 month old. On Friday it stopped working, so I took it to the garage ready...
Evening all, I’m looking to install an outside light as a spur from a socket on a ring main. There is already a spur from this socket supplying...
