Discuss 3rd Party Testing in the UK Electrical Forum area at ElectriciansForums.net
I got a TEXT message (i dont know them and i cant find out who they are from the phone number)
"Hi speaking from Indeed
Are you available to give electrical certification for a job at Melton Mowbray?"
Guessing they have seen my CV online on Indeed and found my phone number and wated me to Sign off and Reg some circuits for them that i didnt install!
This is like Dark Area for me, as to me that is 3rd Party and when i talked to Napit about it, they ripped my head off for talking even about it
NICEIC where saying you can do it but Not great to get in to it.
I think the way around it, is if these where People that worked for me and i was just doing the testing and signing off. So i MUST be able to see that the cable is the right size all around the circuit (no chop and change and cheating) as my name is on the Cert. This would be ok.
I played to the rule, but this can be bent a LOT.
JUST me THINKING over the TOP HERE..
If i hire myself to another company just to do the Testing for them and the Report.. is that 3rd Party Testing
But if i Hired these guys to do the Wiring and I tested it that is OK
I did have once a guy offer me £50 to do the testing and Reg the circuit and i said no
Now wondering if i should just twisted things and said im just testing and reporting it than play within the Napit/NICEIC 3rd Party rules (some years ago now) so im not sure what the rules are now.
I guess it gets complex if i am testing it and its wrong, and i've put my hand prints on it
Unless they are offering up a big bag of cash to give them a certificate for their already finsihed job, I would walk away
There is more to this than just testing and as you say you haven't seen the bare bones of the installation. Initial verification is verifying the installation meets the relevant parts of BS7671 and that comprises more than just testing. Walk away.
Building control around my area will accept a EICR if there is no Part P sign off so seems pointless registering with a scheme sometimes if its costing you £1200 a year and £4+ per sign off if you can just bang out an EICR for nothing.
Nobody really seems to be following up any work carried out by non certified people as far as I am aware, but willing to be proved wrong.
I wont sign anyone's work off, as why should I be the one who has to have all the books, scheme fees and liability etc because someone else cant be bothered to do it themselves, or shouldn't be doing the work in the first place.
As with our local BC they too will accept an EICR if the original installer has disappeared or not returned to finish the job! I have done this a couple of times now for customers who have been led down the garden path with all in builders that have had unregistered sparks on their books! But with lots of not verified's in boxes on the report as how do I know where the cables have been routed or what lurks beneath the surface, and I don't like doing it!
I wouldn't put a part P cert on something that I haven't installed, that is just asking for trouble in the long run!
Sy
Good point SparkySy , i didnt think about "If they would of Routed the cables correctly" would be a hell of a lot of trust
doing a job for a Rubbish Manager (i want to use bad words for him but i must be Angelic) putting lights in a Unit and he wants the whole system wired on the ground and then Pushed in to the units Drivers/Connection box, so the Holes between joists are 52mm big .. To me we should be pointing in the middle of the Joist, as little hole as posible
This guy said he has passed his 17th and 18th Wiring Regs but i feel he HAS NEVER read them at all and doesnt use them, Pass the Exam and Burn the Book, Why i want out of the current place before i get my hands burnt with being linked to him.
My Ex Manager told me i have to stick it out till i find a new job to walk in to, pointed out id sooner stack shelfs at ASDA than this. He told me they dont like Breaks like that in the building trade
They must be some very thick joists to accept a 52mm hole, most I have come across you can if your lucky get a 32mm but most are nearly always 25mm due the the lack of meat in modern builds!
Sounds like you would be much better off out of there imho!
I honestly do not believe that an EICR report gets much reading from BC past page 1, after the address ant the word satisfactory has been seen.
In the extent and limitations you could probably put this certificate only covers the correct address and current date and nobody would think anything of it!
All they see is another satisfactory installation at 123 Limitation Lane!!!
Reply to 3rd Party Testing in the UK Electrical Forum area at ElectriciansForums.net
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
I’m just finishing my L2 2365 at college in the evenings and plan to do the L3 2365 with the same college as an evening course. However I would...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
