- Reaction score
- 17,246
Doing work in a house the other day, and noticed they didn't have any smoke detectors... (well, one.. and it was a small 9v thing)
So ive sent in an estimate for what's needed... 3 smokes, 1 heat and a couple of Co.
However.. its an old property in the village and there's a little add-on to the building. Might have once been a shop belonging the house... but now its a self contained rental property owned by the main house owners. I'm asking them via email if there is already smoke detectors in there.
The problem arises that there is an access door from one property to the other. Actually, a double door... There is a door on each side of the party wall, with slide bolt locks. But i do not think they are fire doors... they will be original to the house, and likely very solid... but not tested as a fire door.
Should the smoke detector system in the main house be linked to the granny annex on the side. Should they have a smoke detector located at the joining doorway to pick up any smoke coming through the door.... or leave them separate and hope they fit a proper fire door?
