Discuss Any Point in Domestic Installer course or any electrical training at 41 in 2022? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
As the title says. I'm really battling with figuring out the best route to electrical training (College level 2/3 v's DI), and to be honest - even though I'm really keen, I'm starting to get a bit disillusioned with the whole thing.
I'm in a technical job currently and 41 so apprenticeship is probably not really for me. Really would like to go down the sole trader route at some point but in no hurry. Only really interested in domestic work and would be interested in EV charge/solar and testing eventually (if I can get CPS registered).
On paper the domestic installer route seems perfect to someone like me but I'm only hearing negative things about that route and domestic installers generally.
Since the changes in 2021, it seems it's more difficult to get the DI with less courses accepted as minimum for CPS - but has the damage been done to the DI reputation and is there no real way in for someone my age/in my position?
Or am I reading this wrong and there is a way forward that I'm not seeing?
I am not sure but the only real way to get into a DI approved Scam is via a recognised Nvq apprentice scheme
There used to a be a back to method via 'time served' which some Scams would accept if you didn't hold a modern Nvq , but that appears to be closed now
Just an FYI that you can do an NVQ without doing an apprenticeship, the Experience Worker Route is a way.
There's also the way of just getting competent and then not registering with a scam. By all accounts lots of local authorities won't even let you notify them as they don't care so doing quality work but explaining they'll need an EICR if they come to sell might be a way forward as much as it will be frowned upon by some.
IMO OP, don't bother with college, it's too big a time sink and you really won't learn anything of real practical value - running in lighting circuits on a 2m x 2m board isn't reflective of real life and the theory can be learned on your own.
I ditched college and went with the 'mates' route and i'm on more money than some qualified sparks now, and learning as i go on the job under someone more knowledgeable than me.
Pretty sure the course I've seen locally gives the minimum qualifications to get on a DI approved 'scam' :
LCL Awards Level 3 - Certificate in Installing, Testing and Ensuring Compliance of Electrical Installations in Dwellings
City & Guilds 2382-22 - Level 3 18th Edition Wiring Regulations
City & Guilds 2391-50 - Level 3 Inspection & Testing - Initial Verification
I rang NIC EIC and they said they confirmed it is enough. But you do obviously need the insurance, docs, portfolio of work and an assessment after 2 years working - presumably on minor works and using building control for notifiable works.
The training provider is also offering City & Guilds 2391-51 Periodic Inspection and Testing course and the City & Guilds 2919-01 Electric Vehicle charging course for a bit more dollar - but not sure if any of it is worth bothering with after what I'm reading about these sorts of courses?!
Thanks, that's a different perspective than I've heard so far. The advantage with the course I've seen is that it's only Sept - April so time isn't the issue really - I'm more worried that I'd just be chucking my money away and wouldn't be able to pick up any work afterwards. As that's the impression I'm getting about domestic installers
Wondering if lots of people are just judging the domestic installer thing on what has happened before 2021 and are not fully up to speed on the changes
problem is to obtain NVQ you need to be working in the industry and able to prepare a prortfolio of works done by yourself. loads of ttext and photos.
Yeah, which is making me think the college NVQ route isn't for me either. So I'm left with DI - but I only ever see bad things written about DI route (possibly due to outdated knowledge?) - so leaves me thinking there's no way in.
I think the NIC EIC, DI qualified supervisor scheme you need the quals above plus specifications, certificates, competence records and complaints for 2 years (plus insurance and all the other stuff). I think (but not sure) for the DI scheme they only assess one job? Might be wrong on that.
You can't do level 3 without level 2 so i'd look into that, unless it's a fast track course then it would take 2 years minimum.
Basically if you can do the work, you'll find people will take you on whether you've got qualifications or not. If you have the quals but can't really do anything, nobody is going to hire you.
I'd concentrate on getting the knowledge together and the 18th edition/ECS card and going from there. But that's just me personally.
Only things I'd say here are that I'm primarily interested in domestic work and the course I've listed above doesn't require level 2 as an entry requirement.
Good point on the quals/no quals it is more important that you can do the work... I'm really looking at becoming a sole trader, probably part time initially, so it's not so much about people taking me on as being (and being able to prove I'm) competent and confident enough to do the work (minor works and a few basic notifiable works at first) . I think that qualifications help with that, although are obviously secondary to experience.
Also bear in mind that there's no such thing as a 'domestic installer' qualification - you would be as qualified to take on work as you are right now after taking it. C&G Level 3 doesn't give you any extra leverage to install domestically either. The only 'recognised' qualifications are 18th, testing and inspection, and the NVQ.
Every other qualification except those three basically means nothing except to the person holding them. Legally speaking you don't need any qualifications to do electrical work of any kind and the level 3 C&G for example doesn't give you access to any accreditation or jobs that just not having it doesn't already give you.
Some employers might see it as giving you competence but really you can do some learning on your own from the book and then go it alone and you'll be technically as qualified as if you'd have taken a course.
The top and bottom of it is this:
No qualifications - can do any electrical work, might struggle to get on big sites as people might see you as unqualified.
C&G 3 - as above.
18th + Testing and Inspection + NVQ - as above except people now see you as qualified and competent.
So essentially the only thing stopping you from getting into the game isn't qualifications it's just knowledge and experience, both of which a course won't give you. You need to be on site. So work out how to get on site.
Reply to Any Point in Domestic Installer course or any electrical training at 41 in 2022? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I've seen a lot of people on here addressing the online qualifications for access training but not talking about the Apprenticeship aspect. I've...
Hi, Just wondered if anyone knows whether there is such a thing as a distance learning version of the level 3 (C&G or EAL) Electrical...
4K
Hi everyone, I'm currently working towards getting qualified as an electrician and am hoping to get my foot in the door with an apprenticeship or...
Electrical Courses
