Currently reading:
Anyone one experienced in large scale cctv systems I Need cctv advise
Discuss Anyone one experienced in large scale cctv systems I Need cctv advise in the UK Electrical Forum area at ElectriciansForums.net
Hi guys & girls, I have a client who wants a new cctv system on his business, He sells cars so has a lot of ground to cover. Doesn’t need any fancy extras just a dvr that can take around 30 cameras, and the cameras image to be clear enough to recognise faces and number plates at a distance of maybe 50M+. Some of the cameras are going to be fitted at over 5oM from the dvr hub.
Has anyone had experience in this, that would be able to recommend a cctv system to use? Or any advice on the matter would be awesome.
Hikvision network cameras and NVR are good, number plate and facial recognition require the camera and lighting to right, trying this over 50+ meters will be a challenge to put it mildly.
depends what you mean in terms of wireless, on a house its fine but on a large scale system like you are using you have normal poe cameras or coaxial they go to a transmitter that sends it upto the main dvr with its own receiver. it saves running loads of cable down to the other end of the car park or site. like i said, have a look on the website i linked above. they do some brilliant kit.
We a customer who has a plant hire company and he went for xvision IP cameras and POE. A chum of his designed the system so we just pulled the cat5e in and installed the kit and he set it all up at the end.
A couple of cameras are on lamp posts and connect back to the main building via wireless access points, just picked up a feed from the post for a socket for the POE injector and WAP. Never had any problems with them afaik.
Cameras are very good quality, can read the serial numbers off portacabins at the bottom of the yard zoomed in and that must be 50m +
Reply to Anyone one experienced in large scale cctv systems I Need cctv advise in the UK Electrical Forum area at ElectriciansForums.net
