Discuss are there Zone 1 Changes? in the Electricians' Talk area at ElectriciansForums.net
the 12v "rule" is a myth put out by a wet-pants showing off his lack of knowledge. 240V is OK as long as it's IPX4
I also found it on the NICEIC website
scroll down and there is an explanation of the zones
Reply to are there Zone 1 Changes? in the Electricians' Talk area at ElectriciansForums.net
Hi, Buying a replacement extractor fan. It falls into zone one with the room setup. Looking at two fans. One is rated zone 1 one is rated zone 2...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
Hi, My alarm system is a Texecom control unit (Premier 64-w) + Keypad + Sounder, and is using the wired zones 1-4 only, with no additional...
Hi does anyone have a S plan wiring diagram that incorporates a third zone to accommodate an underfloor heating system like polypipe? Would...
