Search the forum,
Discuss Ariston 1400wd pcb damaged in the Electrical Appliances Forum area at ElectriciansForums.net
Hi all. New diy member here. I have an Ariston 1400wd washing machine which has a burnt out 7 pin chip on the main pcb. I can read 311 411 on it but the code above is too damage to read I can make out that it starts with T and ends 4pn. Ideally I would like to identify the chip so that I can replace it. Ariston has the board as discontinued.
Something like a TNY264PN, which is a 7-pin MOSFET switching IC, it appears in some washing machine control PCBs.
But beware, it might have failed because some other related component has failed, I'd be wary of just putting in a new device without checking. Or buy more than one (they are cheap), so if it immediately blows up, you have a spare after finding any other failed parts!
Thanks for that. I will get a couple and see how it goes
Type any numbers written on the PCB, that might be part numbers, into Google and see what comes up. I did this a while ago with a Bosch washing machine PCB, and up came a Chinese web site with a picture of the board in question, four red arrows pointing at four components, and a picture of a small plastic bag containing those four parts with a price of a very few dollars beside it.
Bought the kit (postage came to more than the kit), arrived after a couple of weeks, fitted all the parts, and the machine has been working ever since.
Reply to Ariston 1400wd pcb damaged in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
I am working at a site with around 100 of these meters installed on various loads. Doing an audit, we found that most of the meters were recording...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hello My dear old mother tried to clean the tiles in our utility room by using a damp rag and I think some water may have dripped into our plug...
4K
